Error E86: No Valid Data
  • keithxxiii
    Just a tech
    • Nov 2014
    • 469
    Hello,
    We have these 50+ number of machines IM C2500/3500/3000 series all connected to a print management called MyQ.
    All of them were installed more than a year ago with their stock firmwares. Now, I wanted to upgrade the firmwares but on my first try of IM C2500, it gives me the error E86.
    I tried using both USB and SD Card to update the package. USB on the O-panel's side, and SD Card for both O-panel and controller side. Tried an older firmware as well but no luck.
    Moving on, i went to another device and still the same. I have checked if the Firmware update setting is prohibited but it is enabled. Tried the RFUT to schedule it but still a no go.
    I am afraid to update it thru @remote because i know in the middle if something happens it will definitely kill my controller board.
    Has anyone experienced the same issue? What fix have you done?
    THanks
    Aye! Cut the crap
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Error E86: No Valid Data
    Can you not just update it on the machine using the application site or SP mode? That way you can see it's not getting tampered with.
    Hit it.
    • dalewb74
      • Feb 2018
      • 1155
      tried using a different SD?
      • tjvincent
        • 280
        Try the SD card in the controller service slot.
          • 37523
          He said he tried that
            • 37523
            Have you tried using RFU firmware through WIM?
            The MyQ has an application may be blocking updates if it is trying to manage memory device printing. It may have an imbedded update tool that has to be used.
            Try uninstalling it on one machine and see what happens.
            • anothertech
              • 1771
              Do it through @remote. I do it every day, it works flawlessly. Also turn on auto firmware update SP5886-111 to 1
              • copier tech
                • 8167
                Originally posted by keithxxiii
                Hello,
                THanks
                Extract the .pkg file with a program like WinRar to a folder called romdata, copy this folder to your SD card & then update using this method. This will overwrite the temporary firmware currently installed.
                • keithxxiii
                  Just a tech
                  • Nov 2014
                  • 469
                  I need to try RFU thru WIM but then I have to upload 600+MB file to the printer. Knowing browsers now don't show the status of the progress while uploading, this might pose a challenge.
                  I also uninstalled MyQ btw, but still gives the same error.
                  For SD Card, I have tried different ones, 4GB, 8GB and 2GB. I even used the SD Formatter app to wipe everything just to make sure I am not missing anything on SD.
                  Now looking at the Service Manual for the SP Modes that were changed by MyQ while deploying it.
                  Aye! Cut the crap
                  • keithxxiii
                    Just a tech
                    • Nov 2014
                    • 469
                    Thanks for this, I have it extracted and will test with the client.
                    Aye! Cut the crap
                    • keithxxiii
                      Just a tech
                      • Nov 2014
                      • 469
                      Printer VLAN does not have internet connectivity. Only the @remote URLs are the ones permitted.
                      Aye! Cut the crap
                      • anothertech
                        • 1771
                        Your SD card is too big. 1gb max. Either get a 1gb card of partition the 2gb to 1gb.
                        • copier tech
                          • 8167
                          Wrong, the METIS will accept max 4GB SD card.
                            • 37523
                            But not all 4GB cards are the same.
                            • anothertech
                              • 1771
                              I can only say, when my 2gb card wouldn't work, I partitioned it to 1gb, then it worked.
