Error E86: No Valid Data
  • keithxxiii
    Just a tech
    • Nov 2014
    • 471
    #16
    Re: Error E86: No Valid Data
    Hey guys,
    Forgot to update you. the software messes up with the sp modes and firmware.
    need to disable skip lr check from sp mode then proceed with the firmware update.
    works like charm
    Aye! Cut the crap
    • anothertech
      • 1771
      #17
      Originally posted by keithxxiii
      Hey guys,
      works like charm
      Can you be more specific? What is lr and what sp is it?
      • keithxxiii
        Just a tech
        • Nov 2014
        • 471
        #18
        Can't define what is LR, but it is under 5886
        Aye! Cut the crap
        • dalewb74
          • Feb 2018
          • 1167
          #19
          i use a 4gb sd card for firmware updates, no partitions. i know you said you have tried different size sd cards. but have you tried a different brand? and what file type are you formatting the card with?
          • keithxxiii
            Just a tech
            • Nov 2014
            • 471
            #20
            Different sizes, different brands. I had to use the sdcard formatter tool as well, different usb drives, none of these worked.
            But when skip LR check was enabled, and package_01 loaded, it worked.
            Even asked my colleague on site to do the same and it worked.
            Aye! Cut the crap
            • dalewb74
              • Feb 2018
              • 1167
              #21
              ok guess i don't know, what is the LR you mentioned?
