3004 CTL Board Replacement
  • ABS tect
    • Sep 2013
    • 511
    Re: 3004 CTL Board Replacement
    Luca and slim, thank you, those flow charts are exactly what I was looking at. Granted I stopped short, I can revisit that.
    But if changing the serial number works I will do that first, I'll let you know what I find to be the issue or solution
      • 8120
      Just replace the controller board & remember to swap the NVram & make sure you order the correct CTL (ex / non ex)
      • luca72
        • Oct 2017
        • 1710
        I didn't read correctly that you needed information for the issue of serial number vs controller, yes, you must necessarily match the serial numbers from sp, otherwise it will give you sc995-01.
