Problem ricoh mp402 in print. Urgent.
  • tullio
    • Feb 2012
    • 268
    print with white tiga. also in copy. total counter 21000.
    new drum.
    • 37059
    Re: Problem ricoh mp402 in print. Urgent.
    Is the paper fed LEF or SEF.
    If LEF you may have a problem with the registration roller/clutch
    If SEF check the side rails in the paper tray.
    • davel
      • Oct 2011
      • 1089
      Clean the LED array.
      • KeviM
        • Oct 2019
        • 324
        It's a small straightforward A4 black and white machine. Most likely culprit is , drum unit, Dev unit, LED array / laser unit.
        Drum unit and Dev unit is very easy to check. Just open the front door and slide out. While you doing that just check for a build up dirt and toner inside the machine and clean it out.
        It's a decent machine and works fairly well
        • anothertech
          • 1757
          Yep, dirty LED array. Ricoh put a nice cleaning brush on the IM350 model just for this problem.
          • tullio
            • Feb 2012
            • 268
            ok. I'll do these tests. I'll update you. Thanks.
            • sandmanmac
              • 3973
              Urgent??!
              C'mon Man!
              It's the Simplest thing imaginable and you haven't even done it.
              100% this is the issue.
              • Codex
                • May 2008
                • 694
                [QUOTE=tullio; 2583255]
                Memento Audere Semper
                • JayPaul
                  • Oct 2012
                  • 305
                  This job is so simple I made a HOW TO guide for customers to carefully clean it. Saved me many call outs, until the PCDU starts causing lines etc then obviously I have to go out replace, update firmware and clean LED flip down section.
                  Would only recommend if you trust the customer enough though, there are some I can't trust to even change a toner on this model
                  • tullio
                    • Feb 2012
                    • 268
                    Resolved. defective drum. thank you very much for helping.
                    • luca72
                      • Oct 2017
                      • 1711
                      I would also have bet me too on the registration clutch!...they are undersized, and I changed one recently on that model
