IMC 4500 black fade
  • lhmy
    • Oct 2023
    • 33
    IMC 4500 black fade
    Hi guys,
    I got one IMC4500 which have black fade issue
    I did change complete PCDU where the pcu is rebuild while the dev unit is from other machine and tested with solid printout.
    things happen when it can only printout around 5k BW and the printout started to fade again.
    I bring back the PCDU and test the unit inhouse and i can see the toner bottle is rotating and the printout is black solid again
    Is it have something to do with the toner? (compact,independent supply as the chip is not working)
    If it does,do i need to cleanup the hopper from compact toner and change to original toner?
    I dont see the hopper damage as there is no depleted warning at the machine
  • mrwho
    Major Asshole!
    • 4299
    Had that problem once on a IMC2000 machine- long story short (several days), ended up being the laser unit. If you eliminate all the more obvious causes, consider this one.
    Relevant thread here.
    Mascan42
    Ibid
    • dalewb74
      • Feb 2018
      • 1153
      generic toner? optics are clean? firmware is updated?
      • Oze
        Ricoh Fanboy
        • 1663
        It'll be the non genuine toner.
        • lhmy
          • Oct 2023
          • 33
          is the part number for IMC laser unit same?
          If so i will try to change this
          • lhmy
            • Oct 2023
            • 33
            compact
            optics are clean since i did do the calibration before leaving
            firmware is updated
            • lhmy
              • Oct 2023
              • 33
              already told the management about the non genuine toner but still.....
              is there any other solution if still want to use this toner?
                • 37495
                Charge them to replace the toner supply system every couple of months when it clogs.
                • druk-serwis
                  • Sep 2014
                  • 7
                  Try with toner supply system. Had it whit MPC3003 and 3004. Looks like the same are in series IMC. Machine run with no errors, SC and even without low toner info. The problem was with toner supply system and broken spiral.
                  • lhmy
                    • Oct 2023
                    • 33
                    i did change this tonner hopper sir
                    and the old one i did open to see the spiral if its broken,but all are in good condition
                    but after changing the hopper i do the tonner force twice and initialize
                    for the time being the machine has run almost 2 weeks without a call from them
                    if it remain,i will throw away the hopper that i bring back (although by the look nothing damaged)
                    • anothertech
                      • 1770
                      Check the black plastic pipe that run from the hopper down to the developer unit, it gets clogged.
                      • hoanganh836618
                        • May 2024
                        • 14
                        When removing the toner hopper, did you notice if there was still toner inside or was it empty? If it is empty, there is a high possibility that the sensor in the hopper has a problem. If there is still toner, you can try going to system sp and entering the code 3050, find color BK, execute 1-2 times, then exit and try printing, if you see the copy. If the print is bold enough, go back to system sp and enter code 3030, find color BK and press execute.
                        I also often encounter the same problem with the c6004 and I do it that way... I'm not sure it works because no one can tell me everything about printers in my country and I have to find out for myself. and fix them... and I don't know if what I did was stupid
                        The article is done by google translate!.
                        • lhmy
                          • Oct 2023
                          • 33
                          I did open and vaccuum this part when changing the hopper
                          • lhmy
                            • Oct 2023
                            • 33
                            the toner is full inside the hopper
                            When u did the force toner and initialize, how long does it last sir?
                            • hoanganh836618
                              • May 2024
                              • 14
                              I almost never have to do it again... in my case, if the toner fades, it's mainly due to the process of changing from genuine toner to non-genuine toner. When the printout fades, I often go to system sp code 3200 to check the parameters. Normally the fading index of colors is about 10.0 to 13.5 or more. after I did the process as I said and did 1-2 test prints it dropped between 7.0 - 9.5. Honestly I don't know what the code 3200 is...
