Ricoh AF1035 streaks
  • brhodes
    • Aug 2025
    I am getting streaks from entrance to exit on copies through the image. Not coming from drum. When I look at the transfer belt there is toner on it where the streaks are. I replaced the transfer belt thinking that it would resolve it but no deal. I did not replace the transfer belt cleaning blade. Would that be the next thing to do?
  • zed255
    How'd ya manage that?
    • 1024
    The blade is more important than the belt itself. Why would you change one and not the other? Stuff like that should be treated as a set.
    • brhodes
      I could not see any "nicks" or "dings" out of the blade so I didn't change it...I only ordered a belt...because I saw the toner on the belt I thought that the belt was going bad...
      BTW - I am not a copier guy....I have built computers most of my life so I thought that I would attempt to repair this Ricoh MFD that my church has.
      • copytechman
        • Nov 2008
        • 949
        That would be kinda like changing your cars windshield when the wipers start to streak!
        A!
        • tcs04
          FORMER Techie
          • 1183
          Are the bands on the back of the copy paper? Are they more towards the middle of the page?
          If yes, change the blade, but leave the centre of the 3 screws out. It's easy to put too much pressure on the screw which bends the blade and the fixing bar giving poor cleaning in the centre.
          • brhodes
            no they are on the front through the text/image. In the middle.
            • copytechman
              • Nov 2008
              • 949
              Ok then, did you stop a copy/print when paper was passing the drum to confirm that it wasnt the drum/drum blade itself?
              A.
              • teebee1234
                • Jul 2008
                • 1670
                Check the mag roller for buildup. Brush away the developer from the mag roll surface, is it silver or coated like it was painted (scratch the surface with your nail)? The mag rolls in this family of mfp's are notorious for this. The toner binds (melts) to the surface acting as an insulation, reducing the bias voltage available and dispersing excess toner to the paper surface and transfer belt. Scrub or replace the mag roll and replace the developer material itself.
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Or.... get a tech in. Replacing parts like developer is something a tech has to do, SP mode changes need to be made, etc etc.
                  Hit it.
                  • teebee1234
                    • Jul 2008
                    • 1670
                    Oops, I missed that line where he states he's not a tech. Definitely not something you should attempt brhodes.
                    • mikadonovan
                      • May 2008
                      • 2931
                      Since the streaks are on the front side the transfer unit is not the problem. If you are running the original through the document feeder and getting streaks but NOT when you lay the original on the glass, you need to clean the scanner glass. Also, you may try yanking up on the left front side of the scanner. People have a tendency to lean on the scanner bending it down which will also cause streaks.
                      NEVER ASSUME ANYTHING
                      • copyaction
                        • Oct 2007
                        • 991
                        no way, a 1035 with streaks
                        • tcs04
                          FORMER Techie
                          • 1183
                          .... BUT better than an MP4500!!!.... MP4000
                          • brhodes
                            Thanks all for the input...I will check the mag roller as teebee1234 stated. I have looked for a tech in my area for this machine but can not find one...any suggestions?
                            • mikadonovan
                              • May 2008
                              • 2931
                              Here's another possibility. If the streaks are WHITE, you need to clean the laser shield glass. It is located below the toner hopper and slides out the front of the machine. While your at it, remove the original glass and gently clean the mirrors underneath it.
