Ricoh af-3260 sc*543
  • Polo-022
    • Sep 2007
    • 486
    I have already replaced hot roller thermistor assy and tomorrow i will replace fuder harness from PSU to fuser module as a Ricoh bulletin suggests for some SC-xxx codes.
    This code appears randomly after a complete print or copy job.
    Does anyone have faced the same issue?
    Thanks for any input!!
  • Herrmann
    • Jan 2006
    • 792
    Make sure that you are running at least engine firmware 1.20.2.08:
    1.20.2:08
    Symptom corrected:
    1.Poor fusing sometimes occurs when the PS printer driver or EFI PS printer driver is used.
    Note: See RTB #RB132020a for the procedure.
    Important: To apply this change, install the following firmware:
    - Engine v1.20.2:08 (B1325402Q) or newer, AND
    - System/Copy v1.23.1 (B1325750M) or newer.
    2. SC543 sometimes occurs if the bypass tray runs out of paper.
    Note: When using System_Copy versions v1.21 or older, this SC was incorrectly displayed as SC992.
    - System/Copy v1.22 or newer.
    the newest version is: 1.23.0.08
    good luck
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • Polo-022
      • Sep 2007
      • 486
      It is running the latest firmware version : 1.23.0.08. i confirm. (By the way, there is no luck in this job, just revenge from the beasts!!)
      I replaced the fuser harness today without success, heaters, thermostats checked by ohmmeter, ventilation fans and filters...
      Thank a lot for your reply!
      • Herrmann
        • Jan 2006
        • 792
        ok, lets try to get logical
        error 543 means, that there is a massive temperature rising wihtin 1 second, so you can exclude everything which leads to an interruption of wires because this will lead to undertemperature errors, not overtemperature. I would check the wiring at the backside of the mashine, beginning from the fuser connector up to the bicu and search for shortcuts against the frame at next.
        Give it a try
