mp 2000
  • tulipano
    • May 2010
    • 124
    mp 2000
    salve vorrei sapere se vi e' capitato mai che quando faccio la fotocopia ha la stampa anche in fronte retro il foglio esce stopicciato e si inceppa. il forno e' stato cambiato anche se la maccina ha 30.000copie .
    il foglio si blocca appene che supera le unghiette all'uscita del forno . questo problema a volte me lo fa anche dopo 20-30-fotocopie continue e anche nelle ricoh 1018.2018 .
    grazie
  • E Winter
    no comprende^^ - english?
    • iMind
      Vacuum Cleaning Expert
      • Mar 2008
      • 1116
      Caio, non capisca, now write english...
      • Vulkor
        • Jun 2009
        • 946
        prejudice would like to know if there 'that never happened when I photocopy the press has also sided sheet stopicciato out and jams. the oven and 'been changed even though the model car has 30.000copie.
        the paper hangs over the claws that just outside the furnace. This problem sometimes makes me even after 20-30-and even in continuous copying ricoh 1018.2018.
        thanks
        Sounds like he is having fuser jams in a Ricoh 1018. Check your fuser gates, the duplex inverter. Clean the picker fingers.
          • 23010
          Actually, it's Italian.
          Hello. Have you ever found a machine that stops and jams when duplexing? The fuser has been changed at 30,000 copies. The sheet itself blocks the sensor beyond the claws at the fuser exit. This problem occurs every 20 to 30 copies consistently, and also on the Ricoh
          AF-1018 and AF-2018 (I'm not sure I see the connection here (?)). Thanks
          grazie
          This is the last time that I'm translating for you. You can do this yourself tulipano. The website is: Free Translation and Professional Translation Services from SDL
          • Vulkor
            • Jun 2009
            • 946
            Well done Blackcat
            • Jomama46
              • 2900
              I don't know, I like Vulkor's translation better. "The translation from Hell"
              sigpic
              A+; Network +; PDI+
              • tulipano
                • May 2010
                • 124
                si e' italiano
                • Vulkor
                  • Jun 2009
                  • 946
                  Blame Google Translation Engine. I just tried the Free Translation link above and I got
                  "You hello I would like to know if yourselves and' arrived ever than when I do the photocopy has the printing also in Front back the sheet goes out stopicciato and jams. the oven and' been changed even if the maccina has 30.000copie. The sheet itself block appene that surpasses the scoops to the gone out some oven. this problem to times does me it also after 20-30-fotocopie continuous and also in the ricoh 1018,2018. thanks"
                  Gotta tell ya. Italian must be a rough language to translate. I don't want to even imagine Russian.
                    • 23010
                    Yeah, that's what I got too. All the individual words translate to something, just not in an order that makes much sense. It's a kind of puzzle. Do we have a noun? Yes we have a noun! etc...
