Lanier ld075 ( richo aficio 1075)
  • copierlady
    • 338
    Working on lanier ld075 ( richo sficio 1075) need to remove the fuser to take it to the shop. What am i missing here? Right side i see to release with black release bar, but the left side has no release that i can see. Any clues for me? Thanks
  • Vulkor
    • Jun 2009
    • 946
    Take off Blue Knob. Take off Brown front cover. Unplug Fusing Web Harnesses (3). Uncrew small bracket on rear top of fusing unit that holds it in. Lift up on unit.
    • teebee1234
      • Jul 2008
      • 1670
      !Watch out for the sensor on the lower front section of the fuser when lifting it! I don't know how many times I've broken it when it got snagged during removal (due to my impatience of course).
      • Eric1968
        • 2458
        You are absolutely right! Happened to me a few weeks ago (impatience...).
        • copierlady
          • 338
          Thanks guys! I WILL WATCH FOR THAT SENSOR. IMPATIENCE? ME?*!
          I'll tackel it again on mon. Have a great weekend.
          • tcs04
            FORMER Techie
            • 1183
            2 tips (obvious?)
            Stick an allen key through the hole in the roller shaft to get the knob off,
            Swing the toner bottle out before lifting, it helps you to remove the unit without breaking the sensor!
            • tcs04
              FORMER Techie
              • 1183
              NEWSFLASH!!!! NO PRESSURE RELEASE SENSOR ON THE AF1075!!!!!!... only on the 2075!
              • copierlady
                • 338
                Ok guys got that fuser removed. Any tips on taking it apart for a rebuild? Also i noticed that the web is not advancing like it should there is quite a build up on the web. Gears look ok. Any ideas?
