Lanier ld075 web not advancing
  • copierlady
    • 338
    Pulled that fuser to rebuild. (lanier ld075) any tips on taking it apart and rebuilding it? Never done it befor any tricks i need to know? Also the web is really dirty like it is not advancing. The gears all look good don't know this machine at all any help would be much appriciated. Thanks
  • msaeger
    • Sep 2008
    • 333
    It's probably advancing if it wasn't it would get sucked into the fuser it's probably really dirty because the hot roller is bad. The one I have seen break is a small white one near the brake pad.
    It's not a hard fuser to rebuild can't think of any tips.
    • zyqwiz
      • Jun 2009
      • 333
      On the web unit, teeth can break off of the white gears so have a good look. The only other thing that happens is the metal ratchet (B1404209) on the brown gear on the orange sponge pressure roller breaks. That normally makes the web spool off though.
      • TonerMunkeh
        Professional Moron
        • 3865
        I had to replace a complete web unit and BICU board a couple of weeks ago for the web not advancing.
        Hit it.
        • copierlady
          • 338
          Ok i'll take a closer look. I expected someone to say the motor that drives it. I guess that doesn't go out without a code poping up huh? Thanks guys
          • TonerMunkeh
            Professional Moron
            • 3865
            No, it can die and not show a code. The only way you know is the web's shredded and the hot roller's goosed.
            Hit it.
            • Fearless V K
              • 620
              Had one with broken gear teeth, and a bad web motor. no code.
              Don't take that toner with me!
              • tcs04
                FORMER Techie
                • 1183
                I have a motor blow. This took out the supply PCB (BICU / IOB... Cant remember!) can be tested in output mode SP5804. I think you need to cheat both door switches.
                As said elsewhere, alaways change the brown ratchet gear an bracket if worn.
                Not hard to change if you follow the manual.
                • copierlady
                  • 338
                  thanks guys it was the metal ratchet broken you can't really tell by looking at it unless you know what it is supose to look like. had to buy the whole web assmbly, took this long to get one in, then i had to send it back because the gear was missing and get another one in. anyway........all done. thanks again
                  • Shadow1
                    • Sep 2008
                    • 1642
                    Funny this should come up now. I had 2 bad motors recently, one of them ran until the web got dirty enough to stick to the roller, but the other generated an SC550 like if the web was out.
                    I think if the motor is completely open or disconnected the machine will detect it, but if it gets stuck there's nothing it can do to detect it.
                    73 DE W5SSJ
