MPC 2050 Original size not recognized from glass
  • nobody-here
    • Mar 2008
    • 237
    [Misc] MPC 2050 Original size not recognized from glass
    Hi guys,
    we're having such a problem on original paper size recognition onto 2 MPC2050.
    The problem looks solved by cleaning CCD but after few hours it came back.
    We changed both optical sensors and re-cleaned CDD with no issue.
    Any clue or advice.
    Vincenzo
    29 rouge unpair manque.... cous cous....
  • Fearless V K
    • 620
    Re: MPC 2050 Original size not recognized from glass
    May have something to do with the adf position sensor.
    Don't take that toner with me!
    • nobody-here
      • Mar 2008
      • 237
      Thanks in advance.
      We checked ADF position and is ok.
      Then we checked sp-4-301 and is looking strange...value is always "00001" even without paper on glass.
      But sensors are new. Any clue?
      Vincenzo
      • mikadonovan
        • May 2008
        • 2931
        I am not very familiar with this particular model, but normally on-the-glass original size is detected by the original length and original width sensors that are under the glass. There should be 3 length sensors and 2 width sensors. The CCD has nothing to do with it. As previously mentioned, the sensors are turned on by the ADF platen cover sensor. (open/closed). If your reading 00001 with nothing on the glass you have a problem with width sensor #2. Check your connectors or replace it.
        NEVER ASSUME ANYTHING
        • sandmanmac
          • 3981
          Originally posted by nobody-here
          Hi guys,
          Any clue or advice.
          Vincenzo
          I just picked up an MP C3500 to refurbish, and it had the exact same problem....updating firmware solved it.
          • mikadonovan
            • May 2008
            • 2931
            That's good info. I have several MPC3500's in the field, but I've not run into that yet.
