MP2510
  • staffie man
    • Aug 2011
    • 59
    [CQ] MP2510
    Hi all,hope you can help.
    My 2510 has a dark shading on one trailing edge corner of A3 & A4 reduction,only when using platen glass not adf,the shading starts approx 4
    inches from trail edge and gradually gets darker until it is like two bands 1 inch wide.
    thanks in advance
  • Jomama46
    • 2900
    Re: MP2510
    Sounds like one of the carriages is not aligned. You woulndt see that in ADF mode. I would start by jigging the 1 and 2 carriages. Also make sure the mirrors are secure and not moving.
    sigpic
    A+; Network +; PDI+
    • staffie man
      • Aug 2011
      • 59
      Re: MP2510
      Thanks for the reply Jomama 46.
      Tried the scanner,couldnt see anything,tried adjusting anyway and just blurred image with no effect on fault.
      • Jomama46
        • 2900
        Re: MP2510
        Originally posted by staffie man
        Thanks for the reply Jomama 46. Tried the scanner,couldnt see anything,tried adjusting anyway and just blurred image with no effect on fault.
        You cant adjust them without the jigs
        sigpic
        A+; Network +; PDI+
        • mikadonovan
          • May 2008
          • 2931
          Re: MP2510
          You can, but it will just blur the image.
          NEVER ASSUME ANYTHING
          • Jomama46
            • 2900
            Re: MP2510
            exactly
            sigpic
            A+; Network +; PDI+
            • Herrmann
              • Jan 2006
              • 792
              Re: MP2510
              Maybe your Scanner Housing is bent. Grap the Housing at the front left corner, and give some moderate pressure from below, then make a Copy again. does something change?
              If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
              • staffie man
                • Aug 2011
                • 59
                Re: MP2510
                If fault is scanner/mirror alignment would there be two distinct bands, also image is visible below shading until it becomes too dark
                • staffie man
                  • Aug 2011
                  • 59
                  Re: MP2510
                  Sorted. whole scanner carraige frame was twisted. Thanks for input
                  • ragajungle
                    A timeless copier issue.
