MPC-3502 sc554-00(holy sh..!)
  • Zeldaman
    • Mar 2011
    • 946
  • SargeNZ
    • May 2012
    • 263
    Re: MPC-3502 sc554-00(holy sh..!)
    Did you try SP 5-810 to clear the SC code before swapping boards around? If it was a failure out of the box it should be worth chasing warrantee.
    • Eric1968
      • 2458
      x2
      Resetting a Fusing Unit error by changing the BICU and NVRAM... That's also a way to solve it....
      • Llama God
        • Mar 2009
        • 1353
        You need to order the complete fuser unit as a spare part. These units have a fuse in that blow and enable the second option in SP5810.
        Alternatively, replace the Eeprom (NVRAM) and repair the fuser. Then, once this is working, back up the NVRAM data (this can be used to restore a "good" copy of the NVRAM data later.)
        The best advice I can give is to back up the NVRAM data on all of your MP/MPc**02 machines and the MPc305.
        I feel your pain, I've been through this shitstorm.
        • Zeldaman
          • Mar 2011
          • 946
          • Llama God
            • Mar 2009
            • 1353
            The error is stored on the EPROM, hence it reappearing. You don't have to replace the BICU, this confuses me.
            • TonerMunkeh
              Professional Moron
              • 3865
              We've been instructed to take backups of all MPC4502/5502 NVram's at install. Apparently then the fix is to replace the fuser and reload the good NVram data.
              Hit it.
              • Llama God
                • Mar 2009
                • 1353
                That's what I said earlier on, the BICU thing is what I'm confused about.
                How's it going, sugar tits?
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  One sentence basically describes it - same shit, different day. Hope the situation's improved at your place anyway.
                  Hit it.
                  • Llama God
                    • Mar 2009
                    • 1353
                    Nope.
                    • Sweden_GBG
                      • Nov 2012
                      • 74
                      • Llama God
                        • Mar 2009
                        • 1353
                        This is exactly what you should do, you're right.
                        • Llama God
                          • Mar 2009
                          • 1353
                          These are the documents you need:
                          • Sweden_GBG
                            • Nov 2012
                            • 74
                            Or found a way to make a new fuse to the old fuser? (blows when first start up).
                            • Llama God
                              • Mar 2009
                              • 1353
                              Well yes, you can try.
                              You can get the spare parts as you can with previous fusers, so that would be the way forward as long as you have the NVRAM data.
