Aficio 350 vs 1035
  • RSCA
    • Jul 2008
    • 112
    Aficio 350 vs 1035
    Does anyone know if the fusers are interchangeable in these two models? There is some differences that are obvious but it looks to be the same dimensions etc. At the very least are the lower rollers compatible?
  • rthonpm
    • Aug 2007
    • 2860
    They look alike, but the thermistors, heat tube, pressure roller and thermostats are all different. You'll more than likely get a fuser code swapping them out. The cleaning roller is the only universal part, as well as most frame pieces.
    • RSCA
      • Jul 2008
      • 112
      Thanks. I did a more in-depth side by side and realized that there are many differences. The manufacturers change the parts model to model but they don't necessarily improve them.
        • 23010
        You'll get fuser errors, because the upper fuser roller is thinner on the 1035. Take it from me. I tried it. =^..^=
        • ZeusGT
          • 271
          Ditto..
          CompTia A+ Certified
          CompTia Net+ Certified
          CompTia Server+ Certified
          CompTia Project+ Certified
          OP Scanshare Certified
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            they're different and they both suck!
            Mystic Crystal Revelations
