MPC3002 CREASING COPIES
  • katash
    • May 2010
    • 221
    [CQ] MPC3002 CREASING COPIES
    Dear All,
    i trust that you are well. kindly assist on this issue.
    the above machine has been creasing copies in the fuser section, i have changed the fuser unit though the machine has done only 26k copies.
    i have checked and no skew before the fuser and duplex and transport checked,has anyone come across this problem,kindly assist
  • Zeldaman
    • Mar 2011
    • 946
    Re: MPC3002 CREASING COPIES
    Hi there!
    Comes the problem really from the fuser? I would take a closer look at the paper-exit-section, they are allways good for some "fun". Best to build it out of the machine and check axis, bushings, guides....
    Greetings...
    • Polarbear
      • Feb 2012
      • 1070
      Katash
      can you maybe upload a photo of a sample creased copy? Are there any tears or folds in the page other than the creases?
      Press the GREEN button!!
      • katash
        • May 2010
        • 221
        Originally posted by Polarbear
        Katash
        just creases and folds will attach the copy later a did a quick fix i hope it will work, increased tension on the registration rollers.will update.
        • katash
          • May 2010
          • 221
          Originally posted by Zeldaman
          Hi there!
          Greetings...
          hi zeldaman,
          the creasing is only at the fuser level be it single or double sided copyiing.
          • Polarbear
            • Feb 2012
            • 1070
            Katash
            What size and weight paper is being used? 80gsm?
            • techsass
              • Dec 2010
              • 248
              Check the discharge plate on the PTR assy. I've had bent fingers cause creases & wrinkles that looked exactly like a fuser problem. I just remove it.
              Something about the 02 series. It's the only one I've had this problem with, not to mention noise & jams.
              (sorry I don't work on this model, but I'm assuming it's similar to the c5502)
              • danpadure
                • Jan 2025
                • 2
                Had a similar problem, indeed caused by the PTR. Cleaned rollers and all good now
                • GIUBOSS
                  • 1433
                  After 10 years from the post I believe it well
                  • danpadure
                    • Jan 2025
                    • 2
                    Well, I just thought a feedback is always welcomed, even after 10 years. Might help someone, as it helped me
                    • MIGUELMARCHENA
                      • Feb 2018
                      • 192
                      En la misma unidad de transferencia de separación verás una hoja con agujas, si están levantadas querrás arrugar y ondular el papel y peor si es el barato.
                      alisarlas o cambiar la pieza .
                      • Popolopo
                        • May 2023
                        • 131
                        Might be pressure roller bearing. This model, the bearing on pressure roller is fixed. If you can't remove it, it already loose and bad.
