"HELD"
    • 22937
    "HELD"
    Samsung SCX-5935 that won't print...
    I'm not sure what to make of this. The customer tells me that she was trying to stop the reception of a 117 pg. fax when this happened. She wasn't so sure what button sequence she used.
    The result is that whenever printing is required the job is spooled to the hard drive, then just sits there forever. There are no recorded errors. If you go to the Job Status screen, the first job on the list shows as "Held". If the first job is deleted or the job order is changed, again the first job on the list becomes "HELD".
    This affects all internal test pages, all reports, received facsimile, prints, copies, literally everything that prints.
    I've changed the HDD and PBA main controller. I've cleared the memory, reformatted the HDD, initialized the fax NVM, initialized the copy NVM, initialized the network NVM. Still no change. Since then I've re-loaded firmware, tried to boot up without the RAM DIMM (totally dead without it), tried to boot up without the hard drive ("Samsung" screen, forever. Never completes boot up.), swapped op panel (no change).
    Any ideas?
    (Finally! A post with all the links! Again sorry for the duplication.) =^.^=
  • copytechman
    • Nov 2008
    • 926
    This may sound dumb but is the paper type set to plain/normal? Just an idea?
    Regards!
    A.
    • JustManuals
      • Jan 2006
      • 9838
      BC............you want the service manual?
      • copytechman
        • Nov 2008
        • 926
        Lol, sorry to say it.. but samsung manuals leave a lot to be desired.... been there and still doin' that!
        Regards!
        A.
        • JustManuals
          • Jan 2006
          • 9838
          You can't beat the price though
            • 22937
            Paul: thanks, I have that one already (bought it from you, actually).
            copytechman: It's showing standard paper sizes/types. Both trays and MP tray all have letter R/plain. I tried other sizes just for kicks.
            The only error to appear was when I installed the PBA main controller. The board's original host was a SCX-5835FN, and I guess it acquires it's new identity from that chip on the controller, because after a few minutes it appeared as a SCX-5935FN.
            There must be some sort of service mode that the customer inadvertently enabled. Samsung doesn't know what it is. The manual sure won't help. You're right, Samsung doesn't write a very comprehensive manual. And the service modes aren't that useful either. Whenever I need real troubleshooting tools, I end up reading signal voltage off the pins on the controller. =^..^=
            • pacman
              I can turn a screw...
              • 318
              Hrm....sorry I missed this before. I know you reformatted the HDD, but I've had almost a similar issue in which the HDD crapped out on a 5935. Maybe replace the HDD all together? Also, try this: Take the HDD out but leave the cable in. When it boots up it should say something about low fax memory. See if it'll print then.....if it does then it's most likely something in the HDD went bad.
              Never mind....I saw you changed the HDD. my bad.
                • 22937
                That, and it won't boot without the HDD.
                This machine is being RA'ed. =^..^=
                • jonezy999
                  just one copy??
                  • Feb 2010
                  • 952
                  Maybe password protecting the print jobs???
                  I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
                    • 22937
                    I thought about something like that too, but that wouldn't explain fax receptions, internal reports, copies, test patterns, etc. =^..^=
                    • pacman
                      • 318
                      And that, is the best solution for fixing a Samsung sometimes....LOL!
                      • copytechman
                        • Nov 2008
                        • 926
                        Agreed!
                        A!
                        • craig
                          service manager
                          • May 2010
                          • 23
                          Is it possible she got into the admin mode ,went to setup and disabled these functions. They can be all turned off there. I know this is a stretch, but we've all been there.
                            • 22937
                            The NVRAM resets would have restored any setting. I don't think that they are capable of getting into admin mode, even by some crazy accident. =^..^=
                            • Marku
                              • Aug 2011
                              • 28
                              Re: "HELD"
                              Unusual issue about this machine. I am now working on a SCX-5935. Original issue was grinding noise. I installed a new fuser (old fuser is frozen). Printed a config page, with no problem and no noise. I then attempted to make a bunch of copies to test. Press start...I got the "job held" issue. Come to find out that the lower pressure roller is melted to the upper heat roller (hence the grinding), followed by an 02-000 (open heat) error.
                              Ruined the new fuser I installed. I am in the process of tracing the cause of this error.
                              "Job held" could mean many things. I'd like to know what is the fix for your problem.
