Samsung SCX 6345 Toner Suppl Error
  • iscott
    • Mar 2010
    • 344
    Customer Put in new Toner and 1 day later got the Toner Supply Error message
    This is a Factory Cartridge.......
    Tried another toner and got same message, also rebooted no change
    • 23008
    I'd take a look at the drive coupler in the back of the machine. =^..^=
    • iscott
      • Mar 2010
      • 344
      Motor Running fine from test mode could not see coupler but the sprocket that spins the toner augar as turning
      • Jeff M.
        • Dec 2010
        • 127
        Make sure the coupler moves in and out freely. Just saw a bulletin for the 6555 on this problem, says the coupler might swell and stick and not mate with the cartridge. Hope this helps. Regards... Jeff M.
          • 23008
          Yeah, I just saw that same bulletin. Apparently, like the Sharp AR-160, the plastic toner motor shaft breaks but not completely through, allowing the shaft to twist and bind the spring loaded coupler. =^..^=
          • Canuck
            Tech Specialist
            • 1713
            Replace the coupling, I've had to change many.Part number JC97-02681A (MEA UNIT-GEAR SUPPLY)
            • copytechman
              • Nov 2008
              • 945
              Yup, been there, done that! Seconding this!
              Regards!
              A.
              • bdcrandall13
                • Sep 2010
                • 236
                Re: Samsung SCX 6345 Toner Suppl Error
                Also, make sure it is the correct toner. A 6555 cartridge CAN fit in a 6345 but will not work.
                • AN36XA
                  Are you talked about toner cartridge or drum cartridge?
                  I have problems with some new (85%) drum cartridges SCX-R6345A, have same ''toner supply error''
                  • AN36XA
                    Can you share that bulletin please on pm? here in europe gspn i cant find that bulletin
