Samsung SCX-6345 multiple copy problem
  • tseto
    • Jun 2007
    • 60
    Hi guys! I have a strange problem with 2 of my Samsung SCX-6345.
    everything works fine except it will not make multiple copies from the glass. It will make 1 copy and than hangs. It may finish the job some times later when it feels like it. multiple copy is fine from the adf. reflash with the latest .76 version firmware and problem still persisted. has anyone run into this problem? thanks in advance. BTW already did a memory clear, no help.
    • 23008
    Re: Samsung SCX-6345 multiple copy problem
    Is it low on toner? =^..^=
    • tseto
      • Jun 2007
      • 60
      no. I solved the problem, issue is with the newest firmware, the newest firmware is not complete. back to an earlier firmware and problem disappears. the newest firmware requires 2 more bin files , also available on Samsung FTP portal.ed.
      • core2
        Hi, you need turn off sorting funcion in machine. I do not know why this is happening but this help on my machine.
