AR M620U Jams right at exit rollers
  • Doug James
    • Jan 2012
    • 935
    [Jamming] AR M620U Jams right at exit rollers
    This machine jams right at the exit rollers. POD1_N. Exit roller Motor is not turning. Motor is hard to find but should I replace it ? Thinking since it happened at once it is a PWB. I am trying to decide whether to tell customer to buy a new one... What could replace this machine like this Sharp. This is a workhorse...
  • JLSam
    • Jun 2015
    • 605
    Re: AR M620U Jams right at exit rollers
    Originally posted by Doug James
    This machine jams right at the exit rollers. Exit roller Motor is not turning. Motor is hard to find but should I replace it ? Thinking since it happened at once it is a PWB. I am trying to decide whether to tell customer to buy a new one... What could replace this machine like this Sharp. This is a workhorse...
    Are you sure it's the motor and not the paper delivery assembly? I've replaced COUNTLESS of those.
    You're right, that machine is a TANK. If you want to replace with a similar, newer model it would be the MX-M623N.
    The newest would be the MX-M654N.
    Sent from my ONEPLUS A5000 using Tapatalk
    • Doug James
      • Jan 2012
      • 935
      I took the paper delivery assy out and cheated it and the exit roller motor never turns on from startup of the machine and after hitting start to make a copy. The other motors do...
      • ZOOTECH
        Senior member of CRS
        • 3375
        Did you run motor test in simulations? You could also disable jams in Sim 7 (?), and see if it is mechanical, or a sensor problem.
          • 23007
          Jam codes?
          • Doug James
            • Jan 2012
            • 935
            Jam codes?
            POD1_N It's doing that everytime. (I'll edit my first post)
            • JLSam
              • Jun 2015
              • 605
              So I checked the bulletin boards. It seems this model has had a lot of problems with Pod1_N jams.
              1. MFP-TB-194: Changes to the Fuser Unit to Prevent Toner Spots, POD1_N Jams and L4-03 Error Codes.
              2. MFP-TB- 165: Change to the Upper CL Guide Plate to Prevent POD1_N Jam
              3. MFP-TB-038: Part Change (Section 48 Item 9) to Prevent POD1_N Jamming in the Fuser
              4. MFP-TB-039R: POD1_N jamming in the Process Unit Area
              5. MFP-TB-017: Part Change (Section 48 Item 12) to Prevent POD1_N Jamming due to UpperFuser Separator Pawl Breakage
              6. MFP-TB-007: POD1_N Jam due to Paper Catching on Drum Separation Pawl.
              While I have never experienced any of these problems. Almost always for me it was the Paper Delivery and Fuser.
              I would start with ZooTechs option and use aging to at least find out if the problem is mechanical or electrical. Run Sim 6 without Paper Del and Fuser.
              My two cents: You said you tricked the paper del and the motor was not turning? The two motors that run the exit are POM1 and POM 2 (SM 6-44) They are part of an assembly that also drives the fuser (PM 89-1 #12) If the problem is not Paper Del and Fuser, then replace the fusing drive unit.
              Good Luck Doug.
              • pohaku
                • 17
                Replace the turnover/transport unit and your problem is solved. Usually the exit lever breaks. You can swap out the lever but you have to remove the unit to do it.
                • Doug James
                  • Jan 2012
                  • 935
                  Big Help thanks so much !!! It is a sensor problem
                  • Doug James
                    • Jan 2012
                    • 935
                    Your right, It's the paper delivery sensors.... Thanks again !!
                    • Doug James
                      • Jan 2012
                      • 935
                      Good Luck Doug.
                      Really Helped Thanks so much !!!
                      • Doug James
                        • Jan 2012
                        • 935
                        Appreciate your help !! Fixed it right up !!
