Sharp 1661 cs SYSTEM ERROR LI-00
  • Pantylotion
    • Dec 2008
    • 15
    can anyone tell me what this error relates to?
  • ZOOTECH
    Senior member of CRS
    • 3375
    Your scanner lock-down is engaged. It's located under the optic area at the front left corner.
    • Pantylotion
      • Dec 2008
      • 15
      would this cause the machine to make a noise when trying to copy? also im looking for a good sharp parts dealer any suggestions?
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1878
        L1-00 means the scanner never left the home position sensor. As was stated, the most common problem was inadvertantly locking the scanner. You can run the scanner in 1-1, or just move it with your hand.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • Vlad
          • Mar 2008
          • 23
          Tmaged is right - this happened many times to me, I phone troubleshoot it. Sometimes it takes cleaning and oiling the metal rod the scanner rides on (rear fram side). Good luck.
          • OMD-227
            If the machine is in a nice, clean environment, remove the lock-down clip totally..... you will never have this issue again. It only leaves a small hole on the underside of the scanner that no-one will even notice..... little chance of dust entering scanner unit if in a good environment. Your choice. Most machines here in Australia seem to have them removed during run-up. Those that dont, will eventually have this error.
            • nilsonmorales
              sharp bulletin
              saludos desde el salvador
              nilsonmorales@hotmail.com
              • chakiris
                • 22
                If the trouble L1 still occurs, then it will be on the main PWB. There's a technical bulletin from Sharp for the repair on this particular trouble.
                • kbrilliant
                  Re: sharp bulletin
                  I appreciate this PDF documentation you've posted. It will help me troubleshoot the [li-00] system error.
                  • JustManuals
                    • Jan 2006
                    • 9838
                    Re: Sharp 1661 cs SYSTEM ERROR LI-00
                    Paul@justmanuals.com
