AR -M450 copy quality problem, pls help!
  • pcernicky
    • Feb 2010
    • 66
    Hi everyone,
    The copy quality was getting bad, so I performed 50k and 100k maintenance, replaced drum, clean optics, and I'm still getting grey sky shot and not solid black, I changed the transfer roller but no luck, It seems that there is a lot of toner left on the drum after the paper pass thru.
    The DV = 80 read out
    I swapped the DV units but the quality was still poor.
    Please help.
    Thank you.
  • bilyahn
    • Dec 2006
    • 1470
    Check the registration unit, take it apart and clean. Have had similar CQ problems caused by poor earth ground. I think there is a tech bulletin regarding this.
    Good luck.
    Bil
    • pcernicky
      • Feb 2010
      • 66
      Which registration unit do you mean bill? Do you have that tech bulletin?
        • 22997
        Did either of the developing units you installed have fresh developer? Developer is a PM part, and the next place to start. =^..^=
        • pcernicky
          • Feb 2010
          • 66
          I tested the dv unit from the copier that i know has a good copy quality and the dv had about 33k on it. still he same outcome. grey not black.
            • 22997
            Have you ran any self prints 64-01 pattern 83? If so, please attach.
            • pcernicky
              • Feb 2010
              • 66
              No I haven't ,I'll do tomorrow.
              • bilyahn
                • Dec 2006
                • 1470
                Just below the drum, Sharp now calls it the PS assembly. There are 2 screws at the front of the machine then the unit pulls right out with a connector for one sensor. When you pull it out look at the rear of the machine below the developer unit. I have found a lot of developer spill into this area. I then take apart and clean the unit. Watch out for the small spring when you take the back plate off. Sorry I can't seem to find the TB I am thinking of.
                • pcernicky
                  • Feb 2010
                  • 66
                  Thx bilyahn, I'll try that tomorrow. is it on the bottom where the DV unit slides out?
                    • 22997
                    No, the registration assy comes out with two or for screws from the left door, and one connector at the rear frame. =^..^=
                    • bilyahn
                      • Dec 2006
                      • 1470
                      Sorry, I should of mentioned you access it from the left side after you open the sliding door. It's the large black roller just below the drum unit.
                      • mtech
                        • Mar 2007
                        • 307
                        Is the toner at 20% or less? Replace the toner and redo all your adjustments then run off a couple hundred copies.
                        • pcernicky
                          • Feb 2010
                          • 66
                          I put fresh toner in and run about 250 copies, same issue, still grey, when I do sky shot i'm getting lighter pattern almost like a mag roller from dv unit every couple of inches. is it ok for dv to be at 80 shouldn't it be around 125?
                          • spotlifter
                            • Mar 2008
                            • 65
                            Check the drum earth plate. Maybe not touching the drum shaft. As for dv, check the connections inside the copier. Toners do spills some around there. I do sometimes get dv value that is incorrect. After trying inserting the dv unit a couple of times, I checked the value has changed. It is probably the connection sticking some toners. You might try also cleaning the TD sensors.
                            sigpic
                            • pcernicky
                              • Feb 2010
                              • 66
                              Thank you all. I cleaned all connections and the drum plate. Still the same problem. I ran a copy and the image on the drum is perfectly black, so the dv and drum are fine but it seems like there is somethong not right with transfer roller. I took it apart, cleaned adjust the pressure springs and still the same issue. I just ordered a new tranfer roller and im replacing it tomorrow. Any suggestions why is this happening, the copier has 30k on the transfer roller.
                              Thank you all.
