i have a problem on a 4501 which calls this code regularly. in the past colleagues have fitted thermistors on two occaisions and also reset sim 44-01 as per the Sharp tech bulletin.
I moved the thermostat washers as recommended in another missive and upgraded the firmware but still have this fault.
all connections look/checkout ok. I can copy 500 duplex colour on this m/c and it's fine but the call comes back. All AC input has been tested and the m/c has been plugged into a different ring main.
yesterday i returned sim 44-01 to default....
any ideas out there???
Bill
Bill
