Sharp FO-4470 Fuser warm up error
  • TommyH
    • Sep 2009
    • 118
    Anyone have any experience with this. My first route would be to replace the fuser but at 250.00 and I don't have another to swap with kind of costly for a test.
    Looking for other suggestions or causes for this error. I have got to the fuser and physically it looks ok. Thanks in advance.
  • OMD-227
    Does the fuser even begin to warmup before the error? If its still cold, then most likely has a blown heat lamp. If it does get warm or hot, then the error appears, could be a faulty thermistat.
    Check continuity of the lamp & harness and check the thermistats.
      • 22995
      I have attempted to rebuild these fusers, and it's a disappointing proposition. The plastic fuser frames snap together. It will be badly warped after several years of use, and the plastic becomes very brittle. You can buy individual parts, but plastic things will break off faster than you can replace them.
      If you're anything like me you'll have to try it for yourself, but remember I told you so. =^..^=
      • JustManuals
        • Jan 2006
        • 9819
        This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
        Paul@justmanuals.com
