SHARP COPIER MODEL SF-2216 COpier displays H 3 error and will not copy
  • Tedonzong
    • Aug 2025
    What is the H 3 error on Sharp model SF-2216 and how do I get rid of it?
  • DavePo
    • Jul 2008
    • 305
    Put it in a dumpster would be my first response as this model was crap from day one. Actually it means the fuser temp was to high. Reset using sim 14. Also I would remove fuser and check and clean the thermistor, and also reset the thermal breaker.
    • bilyahn
      • Dec 2006
      • 1470
      It is a fuser code for high temperature. You can try to reset it by entering simulation mode. C, 0 ,0 C then enter the number 14 and hit the start button. Machine will reset but if code comes back there is something wrong with the fuser. I would take it out and look at the rollers to see what they look like and clean the unit. Or replace the machine. This one is pretty old.
      • Tedonzong
        Thanks for the response,I did the C00C 14 and also pulled out the Fuser (looks like tonner catridge) wiped around as some powder ink came out and put it back to no avail.
        I hope I was doing the right thing as I am not tech Savy. Hope I could still save the copier.
          • 23010
          On the control panel of the copier: Clear, Zero, Zero, Clear
          (C, 0, 0, C)
          You're going to have a lot of difficulty getting replacement parts for this beast. If it's not in pristine condition, I wouldn't waste my time on it.
          • CCS
            • 266
            I have used parts in stock if you need any....
            But this is a dumpster bound copier, they were not a favorite of techs, very poor design...
            I have one left in the field, hope its updated soon, lol.
            • lky1978
              • Mar 2009
              • 483
              i think the correct simulation should be c interrupt 0 interrrupt 14 ready.
              for model sf7300 series, sf7700 series and sf2x14 series only using c 0 0 c
              • Tedonzong
                I have tried C014 stilol no change
                I suppose Interrupt is not a particular character.
                Thanks for all your above contributions.
                If I finally cannot get it fixed then I will have no choice than to junk it.
                • DINGO
                  • 661
                  re
                  Hi
                  you must perform C , INTERRUPT, ZERO, INTERRUPT, 14, START,(THAT MEANS COPY)
                  if the code not fix the issue, chek:
                  -fuser lamp
                  -if the termostat is open?
                  -clean the termistor and chek if is good.
                  but y thynk that was, or the fuser lamp burn, replace, or the termostat open, close it,
                  good look
                  • Tedonzong
                    Thank you all, this time it worked and the H3 code disappeared. However it is not picking up paper from the bottom tray and displays the Misfeed signal 8^v indicating the right side. I have performed the instructions for misfeed removal on pages 22 & 23 of the Manual but still cannot get it to pick up the paper; any input will be appreciated.
                    PS
                    the only good news is that the By-pass works OK
                    Thank you all again.
                    • bilyahn
                      • Dec 2006
                      • 1470
                      I generally clean the half moon rollers that pickup the paper and also clean the clutch (take apart and re-grease) that drives the rollers. Actually I think I have the wrong machine again. I still clean the clutch but I don't think this has the half moon rollers (sorry been a long time since I worked on one).
                      Good luck.
                      Bil
                      • Tedonzong
                        This time it worked, Thanks every contributor, the H 3 code disappeared but the 8^v MISFEED error comes up as the copier will not pick up from the bottom tray. The By-pass works though. I will appreciate any inputs.
                        Thank you.
                        • DINGO
                          • 661
                          re
                          hi
                          first do wath Bilyahn said, and pay atention at the tray posicion, because sometimes the tray broken on the right side, and not stay in a correct position.
                          try do o little pressure on the tray and push start copy.
                          and try to put the paper in A4 and change to A4R, and look wath hapenned,
                          do not forguet that when change the paper posicion in the tray, you must set to in the control panel, if not you have a missfeed to.
                          good look
