MX-2600N Scan quality
  • Bani
    • 34
    [CQ] MX-2600N Scan quality
  • Nachoman4life
    • Oct 2007
    • 212
    Have you tried calibrating the scanner with a SIT chart?
    Where the heck is my spring hook?
      • 23008
      To increase the scanned density for Image Send/Scan, adjust Sim 46-08.
      Make the following setting change for RGB
      A: Adj Low Density point from 50 to 65 (Low density is made lower).
      B: Adj High Density point from 50 to 1 (High density is increased).
      This will help big-time. =^..^=
      • Bani
        • 34
        Thank you blackcat4866, I know this bulletin about this settings, but it is
        a little bit better, but it stills very bad against the copy quality.
        And Nachoman4life, I have this problem also on my machine in the office and this
        machine is new, and I have never used the SIT chart.
        Is this calibration necessary when I install a new machine?
        • bilyahn
          • Dec 2006
          • 1470
          The SIT chart is recommended but not necessary/required. It is very pricey and has a short shelf life so if you do not have a lot of color machines it may not be worth it.
          Good luck.
          Bil
          • Bani
            • 34
            I obtain a SIT chart at afternoon and calibrate the scanner.
            Regrettably it looks not better than before.
            • vlad_robas
              • Oct 2006
              • 225
              Maybe if u would atach here a scan it would help.
              Just a thought
