Sharp mx-3501 L4-31
  • sc3
    • Mar 2011
    • 20
    [Error Code] Sharp mx-3501 L4-31
    Hello
    Trying to find part numbers for the fans below the black toner 2 side by side. and the two above the fuser called paper exit the other tonor motor fans. could not find them in my manual
    Thanks for your help. SCIII
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Sharp mx-3501 L4-31
    Look in the Index portion of the parts guide - look for NFAN..., it will show all sections and item #s of the fans.
    Section 37 has your two fans in the delivery unit, not sure of the two below black toner.
    • sc3
      • Mar 2011
      • 20
      Thanks,
      The 2 over the fuser were easy to find its the other ones I'm having trouble with, Took them out and cleaned them but still no luck so got to try something diff.
      • bilyahn
        • Dec 2006
        • 1470
        Originally posted by sc3
        Thanks,
        Hard to tell from the parts guide but it looks like section 48 part # 101 LSU Radiate fan is the part that you are looking for. Don't know why they are calling it that since it is shown on the frame under the toners.
        Good luck.
        Bil
        • ZOOTECH
          • 3375
          Sorry, the updated parts guide doesn't have an Index section.
          • sc3
            • Mar 2011
            • 20
            Thanks Guys
            I found that one but didn't trust picture, only one way to find out now.
            SCIII
            • Ednicarl20
              • Aug 2011
              • 25
              We encountered that error code in MX-3500 the 2 fan is located at the top of the black drum/dv unit. Just remove the transfer unit, it is very easy to find, you need only thumb screw to remove both of them.
              Good luck...
              • Ednicarl20
                • Aug 2011
                • 25
                MX-4100.pdfBefore I tried search for this fans in MX-3500 parts guide but sadly I couldn't find it...
                hope this could help...
                • Toner Boy
                  • Aug 2007
                  • 366
                  3501n_deliv-fans.pdf<br>Hope this works - NFANP0077FCZ1
                  Replaced one last week for same code, but MIGHT be the toner fan above primary tx belt unit.
                  • nightshade
                    Chromographic Supremesist
                    • 158
                    Originally posted by Toner Boy
                    [ATTACH]11548[/ATTACH]<br>Hope this works - NFANP0077FCZ1
                    I carry those 2 fans (above the delivery unit) they burn out quite often from the heat of the fuser. They were the main reason many of our techs have been replacing the unit for, what a waste of money that is!!
                    • sc3
                      • Mar 2011
                      • 20
                      Update on L4-31 Sharp added 2 new fans instead of the one old toner fan. they don't last either.updated in march 2011.
