Sharp ARM205 Copies Only Distorted
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [CQ] Sharp ARM205 Copies Only Distorted
    We have a Sharp ARM205 that when printing from the computer the prints look OK, the self-print tests (simulation 22-6) look perfect and scans look good when scanning to PC via the ADF feeder and then viewing. When you make a copy though, the copy (via the ADF and the platen glass) comes out stretched in the front to rear direction only with only about the top 2.5 inches of the original showing on the copy. In addition, it has repeating horizontal void lines in between regular repeated writes, similar to when the LSU is failing but the prints/self tests are fine (and LSU simulation test is OK). I was suspicious of the CCD or the PWB that runs/controls it until I saw that the scans look great.
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • ZOOTECH
    Senior member of CRS
    • 3378
    Re: Sharp ARM205 Copies Only Distorted
    Well, you have pretty much narrowed it down to optics - that would be a good place to start.
    • Dark Helmet
      • May 2009
      • 868
      Sounds like your opitcs are not traveling very smooth. Clean and lubricate the rails.
      • BMSInc95
        • Sep 2011
        • 66
        If your copies come out distorted at the trail edge front to rear then you have a fusing issue. there is an update adding shims to the pressure springs. The pressure is uneven in the fuser unit. Generally this happens on 14 inch paper. hope that helps.
        • BMSInc95
          • Sep 2011
          • 66
          Sorry read thread again and it sounds like the LSU has a lens that has moved out of place. Weird that prints come out OK. When you test the LSU it only checks that the polygon motor is turning.
            • 23010
            I must disagree BSM. If the laser was the cause it would show on self prints and printing, which is does not.
            Dirty scanner rails, a cable problem, or perhaps a loose scanner drive belt could account for this. I had a Leopard once that the scanner drive belt jumped. The rails were clean and oiled, and I repeated it to be sure. The cables were not excessively tight. The scanner belt is tensioned by a spring. As an experiment I threaded a few self tapping screws through two convenient, unused holes, applied slightly more belt tension then secured the motor mount. AFAIK it's still working. =^..^=
            • igi
              • 1507
              Hi
              please check big fat white cable between CCD and PWB
              good luck
              • MFPs R Now PCs
                • Jul 2011
                • 156
                Customer wanted to replace copier and this machine will probably be scrapped, we never did get it to work properly at the shop. THANK YOU for all of the suggestions!
