AR-205
  • rbell12
    • Aug 2006
    • 83
    [Jamming] AR-205
    Jams frpm tray 1 when running more than 1 copy. first copy does not exit fuser and 2nd copy has no image just a line across page. have tried cleaning feed clutch with no results. We are new to these boxes and have access to service manual. But, can't find anything to help there. Anyone out there can possibly give a direction to look, I would greatly appreciate it. rb
    • 23009
    Re: AR-205
    This sounds really familiar, but I can't quite put my finger on it.
    Check that the paper size programmed for the tray matches the actual paper size. If it doesn't match you'll get jamming just like this. =^..^=
    • vincent64
      • 382
      Re: AR-205
      Could be tray setting, also check the fuser gear on the fuser roller, that tab has a bad habbit of shearing off sometimes and will give a jam that stops right at the nip of the rollers, may even pas one sheet.
      After a while it will jam all the time right there.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1887
        Re: AR-205
        Replace the sensor under the resist roller. You have to flip the machine over & take the cassette out to get to it. Kind of a pain because you also have to pull the back off to plug the sensor in.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • mojorolla
          The Wolf
          • 2627
          Re: AR-205
          Check the fuser drive gear 45T. There is a retrofitted gear for this. The second page with the line is most likely from the drum when the systems stop suddenly because the first page didn't exit the fuser.
          Does it feed from other trays or the bypass? If so, then the fuser isn't the problem.
          • spotlifter
            • Mar 2008
            • 65
            Re: AR-205
            I'll go for the fuser DMC actuator and the return spring since you mention the 1st copy didn't finish exiting.
            42. MLVEP0026QSZ1 - DMC Actuator
            44. MSPRD0118QSZ1 - Actuator Return Spring
            sigpic
            • rbell12
              • Aug 2006
              • 83
              Re: AR-205
              Many thanks to all who replied. turned to be the tray setting. i appreciate all the feedback. rb
                • 23009
                Re: AR-205
                Congratulations! =^..^=
                • timonit
                  Re: AR-205
                  You Can test the sensors with TC 30-1. I have had this issue with the exit sensor . I believe the jam indicator will light if exit sensor switched
