Sharp AR M205 ADF keeps binding
  • Doug James
    • Jan 2012
    • 935
    [Jamming] Sharp AR M205 ADF keeps binding
    Customer said this started after I serviced the machine a few weeks ago. When their I had just cleaned the pick-up tires on the adf. The problem now is unrelated. The paper will feed a few sheets normaly then "all of the sudden" seize up. I troubleshot this thing for a couple of hours and still cannot figure it out. Bad motor maby. That is what makes the most sense... Appreciate any help !!! Thanks so much
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: Sharp AR M205 ADF keeps binding
    I guess the easiest thing to do would be determine if your rollers are slipping or not turning at all. That should help you narrow down the cause. If they're slipping, no amount of cleaning will do and you'll likely have to replace them. If they're not turning at all, then there's another problem at hand.
    I assume you've checked the paper path and found no obstructions? Have you changed the sep pad on it?
      • 22991
      Jam code?
      • Doug James
        • Jan 2012
        • 935
        Jam code says -1 Nothing about it in AR R6 documentation. No obstructions in paper path. Wonder if pick-up assembly is binding somehow. I sure am having trouble pin pointing it if it's their.
        • Akitu
          • Oct 2010
          • 2595
          Jam code?
          These machines aren't sophisticated enough to show jam codes, only jam locations. Quite a pickle to swallow when troubleshooting over the interwebs.
            • 22991
            These particular document feeders have two common problems:
            The spring clutch that drives the feed roller tends to slip.
            The registration roller gets dirty, and the paper slips against it.
            In the first case, clean and re-grease the spring clutch.
            In the second case, dis-assemble the DF to clean the registration roller.
            • Doug James
              • Jan 2012
              • 935
              That spring clutch is got to be where the problem is. I didn't take it out but the problem seems to be from their.
              Thats a greta place to focus. Thanks so much !!!
              • oldrn
                • 166
                As Akitu mentioned, more info is needed. Does the pickup roller drop down onto the paper but not pull the paper in? If the pickup roller drops down, is it turning while it is down? How far does the paper travel when it jams? When it "seizes up", is there any noise indicating a bind in a gear or motor? There is a one-way clutch related to the paper feed roller that causes problems.
                • draph
                  • 132
                  When you last serviced the machine did you remove the ADF?
                  • Doug James
                    • Jan 2012
                    • 935
                    No, just cleaned the pick-up tire
                    • draph
                      • 132
                      Does the ADF motor make a loud buzzing noise when the problem occurs?
                      • Doug James
                        • Jan 2012
                        • 935
                        Yes it sure does, really loud.
                        • MHeon71
                          • Oct 2008
                          • 489
                          It may be the DF board. It is not exactly the same model but would be considered the same family. Try bulletin AR-SP2-002 - Document feeder generates noise or stops cycling.
