SHarp MX2700
  • Larhal
    Semi Retired
    • 533
    [CQ] SHarp MX2700
    We received in a used MX 2700 in.
    This is new to me. I have the service manual. The unit was printing light in all colours when doing test patterns. When printing Black it is dense, only in full colour prints it is light. Copied light also.
    I changed Dev units, Drum units transfer belt and did all the prescribed setups as per the manual. Still have the same problems. It also won't read the chart from the colour balance auto adjust.
    Look we are not a Sharp dealer but a small Ricoh service group. Yes Ricoh trained.
    Any Ideas where I should go to get this correct?
    All input would be appreciated.
    Thanks,
    Larhal
    Larhal
    Retired Part Time
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
  • harleyrider
    • Oct 2011
    • 348
    Re: SHarp MX2700
    Too many things to mention. What simulations did you use and or reset so far?
    • mojorolla
      The Wolf
      • 2570
      Re: SHarp MX2700
      On this model, check the LSU shutters are opening all the way.
      It probably is failing when scanning the charts because the image is too light.
      • Larhal
        Semi Retired
        • 533
        Re: SHarp MX2700
        Hi all,
        1- LSU shutter is OK, checked that.
        Simulations used are as follow
        55-22
        46-24
        26-53
        67-24
        24-4
        24-7
        Kind of lost here do not know Sharp's.
        Larhal
        Larhal
        Retired Part Time
        • faxman28
          • 436
          Re: SHarp MX2700
          follow this procedure in attached bulletin, also do you have samples.
          • harleyrider
            • Oct 2011
            • 348
            Re: SHarp MX2700
            I don't see 25-2. Follow the above bulletin.
              • 22929
              Re: SHarp MX2700
              I don't see the developer stir in there: simulation 25-02. This is an important one.
              Then re-do the calibration. =^..^=
              • Larhal
                Semi Retired
                • 533
                Re: SHarp MX2700
                I printed out the Tech bulletin and will follow this verbatim, Also I will do the developer stir, I will advise of my results.
                Thank all for your contributions of knowledge.
                Larhal
                Larhal
                Retired Part Time
                • Larhal
                  Semi Retired
                  • 533
                  Re: SHarp MX2700
                  Hi All,
                  I performed the required items on the service bulletin and low and behold, its alive again.
                  Want to thank you for your contributions , Great help.
                  Best regards,
                  Larhal
                  Larhal
                  Retired Part Time
                    • 22929
                    Re: SHarp MX2700
                    You're welcome. =^..^=
                    • harleyrider
                      • Oct 2011
                      • 348
                      Re: SHarp MX2700
                      no problem
