MX-2700n bell shaped impression on copies and prints
  • ohightower
    • Aug 2014
    • 33
    [CQ] MX-2700n bell shaped impression on copies and prints
    nonreply_20141124_143601-page-001.jpgnonreply_20141124_143601-page-002.jpgnonreply_20141124_143601-page-003.jpgnonreply_20141124_143601-page-004.jpgWhats causes this?
  • serviceman
    • Jun 2009
    • 71
    Re: MX-2700n bell shaped impression on copies and prints
    I would start with the transfer belt.
    • mttech
      • Mar 2014
      • 127
      Check your primary transfer belt for something stuck to it.
      • ohightower
        • Aug 2014
        • 33
        I check the primary and the secondary transfer belt it had that impression on it but it would go away when it cleans itself. This impression only comes like every five copies. The other copies are nice and clean could it just be the drum needs to be replaced or something else?
        • serviceman
          • Jun 2009
          • 71
          When you say you checked the primary belt, did you actually pull it all the way out of the machine? Or just ran blank copies through? I'm fairly certain your issue will be found in the primary belt. A crack in it or the thin sides of a label stuck to it...
          • faxman28
            • 435
            If it's every five copies ,I would talk a very close look at the primary transfer belt, remove and turn by hand. if it was drum it would be repeating on the page . like others mentioned it is usually label stuck to belt, i have also seen broken belt cause this similar image quality.
              • 23009
              The only thing long enough to make a repetitive image that long is the primary transfer belt. My guess is that the belt has delaminated (layers separating) and it's no longer flat, and no longer cleaning properly. =^..^=
              • NeoMatrix
                Senior Tech.
                • 3513
                Please keep us informed of the result.
                • Foxhound
                  • Mar 2014
                  • 33
                  Blade flip? deffinately X-fer belt unit. Run full color if you get Brown in the bell area its blade flip.
                  • ohightower
                    • Aug 2014
                    • 33
                    I replaced the primary transfer belt unit and that fixed the problem thanks for all the help!
                    • lenovos
                      • Oct 2012
                      • 140
                      [ATTACH=CONFIG]27223[/ATTACH][ATTACH=CONFIG]27224[/ATTACH][ATTACH=CONFIG]27225[/ATTACH][ATTACH=CONFIG]27226[/ATTACH]Whats causes this?
                      I replace the whole transfer belt, but a new cleaning will probably solve the problem.
