Sharp al1631 light copies
  • copierlady
    • 338
    Reposting told you i was to stressed to think! I posted on the wrong forum. Sharp al 1631 light copies on lead edge . Gets worse as you make more copies. New drum and toner installed not helping. Help!!! Thianks
    • 23008
    You say you replaced the drum. Was it a drum only, or a drum unit with a primary corona unit?
    This sounds like a dirty primary wire or grid. =^..^=
    • copierlady
      • 338
      drum
      yes it was a whole drum unit and the machine was doing the same thing with the old drum unit. could it be the charge in the door? thanks never mind the charge in the door i changed it and no results. i also changed out the drum unit again just to be sure the customer was giving me the right info (but they always do don't they?) and that didn't change anything either. i hate these little machines!
      • schooltech
        School District Tech
        • Jun 2008
        • 504
        Did you check the dv drive for the toner/dv cartridge? And, is the cartridge a new one?
        Yeah, these aren't my favorite machines either, but I usually keep them going.
        Repost what you've found about dv drive and with the quality of the toner cartridge. Like I stated before, I refill these all the time and they can sometimes not work that well if they get tired.
        Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
        • chakiris
          • 22
          Have you checked and cleaned the main and transfer charge unit? Please clean the corona wires and see if the copy has improved.....
          • swagreis
            • Jun 2008
            • 92
            pls remove the optical unit frame untill u reach the laser unit and disassemble it and clean it inside (polygon motor and mirrors)carefully u will get a very good copies
            i did that operation in ar-150 series
            i think it is equivalent to al 1630 series(A4 size)
            • copierlady
              • 338
              sharp al 1631 over it!
              Thanks guys but i have done it all new oem supplies,down to cleaning the lasor and mirrors. Still light copies on lead edge. Is it possable for dirt to get on top of the lasor glass and if so how do i get to it. I know it come out of the copier completly in some models but i can't see it if it does in this one although i'm seeing red right now! Thanks
                • 23008
                This is a delight. You have to remove the whole scanner off the top of the machine, then the delivery path, then there it is. It takes a full hour if you know exactly where your going, to see the laser.
                If you decide to clean the inside of the laser, please keep in mind that you must never contact the polygon mirror with anything. I used a very soft cotton pad, and scratched the hell out of it. Air Only! You can wipe the lenses and slit glass with a lint free cloth.
                Have fun! =^..^=
                • jctech
                  • Oct 2008
                  • 13
                  change your toner cartridge and if it still get you clear copys try verifying the power suply board and it tensions.
                  Information is meant to shared not sold!!!!
