Scan to email stopped working
    • 8298
    Re: Scan to email stopped working
    Scan to email via a Gmail server works A-OK on eB3/eBX but you need to add several changes to the normal way you set up this email server.
    1). Date & Time. Make sure you are in the correct time zone.
    2). SMB Session. Make sure you change the NetBios name away from the default.
    3). Email tab. Default subject name. Make sure you change away from the default.
    4). Default Body string. You need to add some text.
    Tested on a e2830c V331 and e347csl V2363
    • dak327
      • Jun 2016
      • 4
      I still cant get to work. I have tried several email services.
      Help !!!
      tried these ffice 365, sengrid, amazon
      • Valintine
        • Jan 2012
        • 147
        Hi SalesServiceGuy
        Thank you for the information. Is there a format that I need to use for the Netbios name?
        • emarkay
          • Feb 2016
          • 2
          #19
          On a 455 and 2830c, scan to email broke for not only gmail, but for hostmonster email as well. I could only get an unencrypted session working through a hostmonster email on either machine. A newer 256 never had a problem.
          After the countermeasure firmware update all is good.
          • tech07
            • Aug 2008
            • 410
            #20
            Blackcat is correct. There are additional patches now for each model. It is downloaded just like normal firmware. Dixes scan to email.
            • didi2005
              • May 2011
              • 401
              #21
              How about e232 or e351c?
                • 23010
                #22
                There is a firmware update for the eS232: version 999.
                The eS351C does not have a firmware update. Maybe because it's obsolete, maybe because it's not needed. I don't know which. =^..^=
                • Woxner
                  • Jul 2011
                  • 854
                  #23
                  I work on konicaminolta we had the same problem when gmail change the TSL firmware did fix this issue. only affected certain series
                  • sneaky41
                    • Dec 2010
                    • 35
                    #24
                    i have the same issue. do you have the firmware number that corrected this issue?
                      • 23010
                      #25
                      There seems to be a quirk in the 4520C version 364 firmware. Here's the story:
                      It started as a simple scan to Gmail request. I arrived and tried to load the version 364, four separate times. Each time the HDD firmware failed H00 "Other". Different USB sticks, reformatted sticks, fresh downloads, 3C-3 reformat ... no success. Then I thought, Hmmmm! HDD! I have one of those.
                      It still would not take the HDD firmware, and now it doesn't like the Scanner firmware either, S00 "Other". So then I thought let's try version 331 and lets do only two files at a time. OS and HDD were successful, then Engine and Scanner were successful. With version 364, same thing. OS and HDD were successful, then Engine and Scanner were successful. Perhaps I might have been able to skip the HDD installation if I had loaded the firmware only two files at a time.
                      Just something to think about. This has come up on bizhub firmware recently, that's why I thought of it. =^..^=
                        • 8298
                        #26
                        e4520c Series
                        System Firm:T450SY0*36A/VTM30.04A *
                        HDD data:T450HD0*36A
                        Machine Firm:21
                        Scanner Firm:10
                        Gmail for scan to email, failing.
                        Google, disabled support for SSLV3
                        Applying patch, should resolve issue.
                        *** Copier FW must be at v331, before installing patch ***
