Toshiba e-Studio 2050c F106_0
  • steanta
    • Oct 2020
    • 4
    Can someone help me? I have this error. I replaced the hdd but it still doesn't work.
    • 22922
    So you installed a HDD. Did you format it, etc, etc, etc?
    • steanta
      • Oct 2020
      • 4
      yes I formatted it but I also tried to format the root partition and I get authentication err..... and when I want to install the system software I get error F106_0
      • djbass
        • May 2008
        • 147
        F106_0 is "ADI-HDD error: Illegal disk replacement detected (ADI-HDD Exchange to SATA-HDD)"
        Meaning you are trying to use a regular SATA HDD instead of the special Toshiba encrypted ADI-HDD which the machine won't allow.
        No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
          • 22922
          Your drive must be labelled: "Wipe Drive", or it is not.
          • steanta
            • Oct 2020
            • 4
            just format where do I find the Wipe Drive option
            • djbass
              • May 2008
              • 147
              He means the drive itself must say "Wipe Technology HDD" like in the yellow area of this image, no other drive will work.
              • steanta
                • Oct 2020
                • 4
                don't write on it wipe technology hdd, it just appears advanced format AF but it still doesn't work
                • djbass
                  • May 2008
                  • 147
                  Correct, if the drive does not look identical to above it will never work.
