I have an es 453 with a c440 csl. The thermistors have been replaced twice and the copier ran about a week each time. Suggestions?
C440
fpcoachTags: 353, 400, back, c44, change, code, connections, copier, dirty, error, error code, format, fuser, fuser problem, fuser unit, grid, half, hdd, ih coil, power, power supply, removal, reset, set, supply, thermistors, time, unit, value
Check all the wiring around the fuser. Cut off the ties, and re-tie them. Toshiba always has tied to tight. -
I replaced thermistors TWICE-still have 440.I think it's the SYS board but I'll let you know what the boys in the shop find out as we've given the customer a LOANER machine in the interim.Comment
Hmmm if you suspect a board I would suspect the IH coil board or the Logic board before I would SYS. Or even power supply! It's not their wall voltage is it?I will not give you service manuals or firmware.Comment
goaplus
goaplus
I have had problems with the fuser connector getting damaged with incorrect fuser removal and replacement. Poor connections causing "C" codes. Remove the fuser and inner cover and look for crackes in the shell. EmujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.Comment
Sorry, my post was not applicable to the 453, I had 3510C series on the brain. EmujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.Comment
