Xerox 700 paper getting stuck 1/2 way in the Fuser
  • georgeact
    • Sep 2023
    • 5
    I have an old Xerox 700 and when I print the paper get stuck in the middle of the fuser so obviously half printed. I thought it's the fuser and purchased a new fuser but it still getting stuck in the same exact position. Any insights/tips will be highly appreciated.
    Please see the video below for more info.
    IMG 5481 - YouTube
  • xcopytech
    • Aug 2006
    • 1792
    Re: Xerox 700 paper getting stuck 1/2 way in the Fuser
    It good idea to post jam code which you got so we can help you
    • georgeact
      • Sep 2023
      • 5
      Thanks for your reply. Code is 077-909
      • Detonation
        • Feb 2010
        • 404
        Do you have access to a decurler assembly ? Might be worth to exchange and see what thatt does. Also check the connectors on the back of the drawer and in the machine for bent pins or paper pieces.
        • georgeact
          • Sep 2023
          • 5
          • xcopytech
            • Aug 2006
            • 1792
            077-909 mean that some of sensor is acivated.
            There is procedure is service manual to check proper NVM and seee which sensor
            • zagrex
              • Dec 2011
              • 63
              Originally posted by georgeact
              check paper size !!!!
