[XEROX DC440] Problem with the margins
  • Enzo
    • Jul 2009
    • 413
    I have a problem with the margins. the copy goes out moved of 5 millimeters in comparison to the original one. how can I resolve this problem? which is the formulation in the menu of system? Thanks.
  • TzALbg
    • Dec 2007
    • 111
    Perform system registration setup
    • Enzo
      • Jul 2009
      • 413
      Where is it?
      • fenave69
        • Jul 2009
        • 16
        you need to enter diagnostics (access #11) and go DC131 then change values of 6-80 side registration and 20-1 lead registration
        • Enzo
          • Jul 2009
          • 413
          thanks you so much. I will try this morning...
          • Enzo
            • Jul 2009
            • 413
            I have only modified the value of "20-1 lead registration" and I have resolved the problem. thank you so much!
            • Enzo
              • Jul 2009
              • 413
              the same problem reappears me! would someone know to tell me which the values of default of the codes are 6-80=side registration (600dpi) all trays and 20-1 = paper feed lead edge registration adjustment? and then I would like to know what the parameter is to modify for moving aloft the edge from ADF. practically when I serve some copies as the adf, the edge is moved me quite a lot in low. thanks.
              • fenave69
                • Jul 2009
                • 16
                dadf lead registration
                to adjust dadf lead registration you have to modify page 21-80 and to modify platen lead edge 21-71
                • Enzo
                  • Jul 2009
                  • 413
                  I will try...
                  • bojans
                    • 1313
                    I think you should clean or replace registration clutch. Adjusting registration in diagnostic won't help you.
                    • Enzo
                      • Jul 2009
                      • 413
                      the registration clutch is new! I have replaced her 2 weeks ago.
