Replaced the exit roller shaft wrap spring clutch 3 months and it fixed it for a while. I put pads on the white turn baffle above the slit glass and problem went away. Is there some sort of retrofit/modification I am unaware of. Any known fix info appreciated.
WC 4118, stretched image when copying thru ADF
