5632 Jams after Fuser
  • mrfuser
    • 1603
    Okay, fuser exit switch is tested good, machine exit sensor tests good. When paper leaves fuser the exit assembly does not turn on to pull paper out of machine. Dead motor? Anyone ever seen this?
    Kelly
  • adriansto
    • 2375
    Re: 5632 Jams after Fuser
    Remove right cover and look at the exit roller shaft from inverter assy.
    You'll see the worn rubber rollers.
    Also look for a code error.
    • livewire
      • Sep 2011
      • 608
      The problem maybe in inverter. Remove inverter our of machne, clean all rubber rolls with fine sandpaper, wash up with water and assembly inverter.
      I my case when copy delivery "Face up" on WorkCentre 238, no paper jam after fuser.
      When copy delivery normal "Face down" have paper jam after fuser.
