Hi i have a Xerox 5334 copier that has worn out upper and lower fuser rollers just wanted to know if anyone has replaced those before if so how long or hard is the process, thanks
Xerox 5334 fuser rollers replacement
Also make sure you get the correct rollers. The 5028 family rollers will fit but will cause wrinkling. One hour is about right for the first time. If the fuser is cold and you have done a few then about 30 minutes.And Star Trek was just a tv show...yeah right!Comment
mgarretson
The Xerox number are:
Heat Roller 22K20701
Pressure Roller 22K49630
Sheesh, sadly enough, I replaced so many of those rollers that even after 9 years, I still remember the number...LOLComment
Super simple to change... I worked on them for years...i can change both in under 15 min. After removing upper fuser roll, you remove pressure roll assembly by lifting and moving toward right(toward transfer assembly). Then remove the pressure roll shaft(might as well replace it, bearings lock and score shaft). Bearing is pressed into end of pressure roll.Comment
