Xerox 5334 fuser rollers replacement
  • techd
    • 32
    Hi i have a Xerox 5334 copier that has worn out upper and lower fuser rollers just wanted to know if anyone has replaced those before if so how long or hard is the process, thanks
  • xcopytech
    • Aug 2006
    • 1794
    Have not work on this machine more then 5 years, but you can replace fuser and pressure roll for about one hour.
    Remove top cover with oil web, then remove heater lamp, fuser roll and then pressure roll.
    Be careful with fingers.
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      Also make sure you get the correct rollers. The 5028 family rollers will fit but will cause wrinkling. One hour is about right for the first time. If the fuser is cold and you have done a few then about 30 minutes.
      • techd
        • 32
        thanks for the reply Xcopytech i was looking at it and couldn't figure how the pressure roller comes out any advice, thanks
        • mgarretson
          The Xerox number are:
          Heat Roller 22K20701
          Pressure Roller 22K49630
          Sheesh, sadly enough, I replaced so many of those rollers that even after 9 years, I still remember the number...LOL
          • Canuck
            Tech Specialist
            • 1713
            Super simple to change... I worked on them for years...i can change both in under 15 min. After removing upper fuser roll, you remove pressure roll assembly by lifting and moving toward right(toward transfer assembly). Then remove the pressure roll shaft(might as well replace it, bearings lock and score shaft). Bearing is pressed into end of pressure roll.
