Xerox 5655 Exit Curl
  • mrfuser
    • 1617
    We have one 5655 at a client that has a lot of curl when it exits the standard finisher. We have tried new paper, fuser, etc.
    Any ideas how to calm down the curl on this beast? Other 5655 units we service are fine.
    Kelly
  • hood4472
    • Aug 2013
    • 17
    Re: Xerox 5655 Exit Curl
    Did you double check the exit rollers? I believe these had a habit of turning to mush. Good luck.
    Robin
    • Flash
      • 378
      There is a de-curl kit for these machines. It involves replacing the inversion unit with one that has a decurl roller instead of the rubber exit rollers. You have to replace the right side cover that is included in the kit also. Let me know if you need the part number.
      • mrfuser
        • 1617
        Yes please give me part number
