Reset Riso GR3750
Hi there
Firstly you will have to get your paper tray unstuck! You have two sensors on the side of the paper elevator upper and lower those two give you T2 errors! Once the tray is at the bottom again then the T2 error will be gone.
Then check paper feed tray I check that your connecter of your paper feed tray is plugged in, and check the safety bar under your paper tray is not, bend and that it makes that safety switch all the time.
Good luck -
Reset Riso GR3750
Dear Sir/Madam
I have RISOGRAPH GR3750 which was giving me message CHECK PAPER FEED AREA and now the paper feed tray is stack and its giving error T2 call service.I want to know i to get read of this CHECK PAPER FEED AREA problem first then How to reset this error T2 call service.How do i solve this problem i am facing?If possible you can also help me with the TECHNICAL MANUAL for this machine.Thank you in advance for helping me.Hope to hear from you soon.
Best Regards
Dimpo
