EZ-RZ press roller
+ More Options
Posts
  • duct tape
    • Jun 2009
    • 87
    EZ-RZ press roller
    I ama having touble with an EZ- 220 intermitantly jaming and the press roller is staying up to the drum holding the drum in the machine. I have cleaned the solenoid and changed the spring that holds the lock for the pressure release. Any ideas?
  • The Doctor
    Hi,
    Had this problem many times on the RP series but never RZ/EZ.
    On the RP series, the Pressure Lever A Assy weld marks failed on the mounting point to Pressure shaft.
    This prevented the pressure lever engaging with pressure solenoid.
    • risografist
      • 18
      This problem only for EZ series.
      It's happend when a lot of papar jammed. imho, it is not hardware problem.
      Try to change firmware.
      • alpererciyaz
        i have the same problem but i dont know how i can change firmware.can someone help me about this?
        • Elle
          Formerly the Dispatcher
          • Jan 2008
          • 51
          pressure solenoid lever maybe?
          there is a new type pressure solenoid lever to help prevent this, see here for the bulletin https://us.riso.com/pls/portal/docs/...20ON%20EZ2.PDF also the rear center frame may be bent allowing more room for the lever to slip off the hook - had this prob two weeks ago and the frame solved it - had this prob when we first started selling this model and the new lever solved it. anyways something else to look for - good luck
          • sandvitch
            tech Elle
            Pliz the link you gave us cannot work unless you give user name and passcode. sandvitch@hotmail.fr
            • duct tape
              • Jun 2009
              • 87
              Thanks, I changed the lever & upgraded the firmware 2 week ago , it seems to have taken care of it.
