Experience Brother HL 6300 broken Fuser
  • i-have-fax-problems
    • Mar 2020
    • 88
    Hello,
    we have a customer who prints about 2000 pages per year with this printer.
    Now the fuser unit is broken the second time in this printer.
    First at about 2000 pages then now again at about 4500 pages.
    Every time the black foil was torn apart.
    Has anyone experience what can cause this except from staples or
    if the customer damages the fuser mechanically with scissors etc.
    Very mysterious and I don't believe the customer does something wrong.
  • tsbservice
    Field tech
    • 7623
    Re: Experience Brother HL 6300 broken Fuser
    We have hundreds of this style engine and from my experience it's impossible same printer to have TWO failed fusers just under 5k without customers doing some damage. Blame them not printer.
    • Samir
      Self-Taught
      • Oct 2023
      • 31
      I would see what toner/drum they're using--we've only had one fuser go bad and it was on a used machine I picked up for parts that was using junk stuff for the toner and drum.
      • havokprod
        • Oct 2012
        • 156
        This
        • dalewb74
          • Feb 2018
          • 1063
          maybe you should describe more when you say it is broken. is it just not working properly? is something actually broken inside the fuser? or is there an error message/ code? i agree with everyone else. i would bet the issue isn't the fuser. but more details might help.
            • Mar 2020
            • 88
            Thank you.
            Parts of the black foil are missing, are torn off.
            • GIUBOSS
              • 1329
              Paper may be fed incorrectly into the fuser, gradually causing it to become damaged
              • Xandy_73
                • Oct 2023
                • 29
                With little use like this, it is something caused by the customer, such as a staple or other object that they may have used to remove paper stuck in the fuser.
                Even if he used damp paper and caused jams, it wouldn't damage the fuser that quickly unless, as I said above, they used an object to remove the paper or removed it the wrong way.
                • Gift
                  • Mar 2011
                  • 2410
                  +1 for blaming the customer, torn apart fuser sleeves are not typical. Perhaps you can find evidence (scatches across running direction) after inspection.
