Brother MFC 7220 leaving ghost images
  • ValSupply
    • Feb 2010
    • 38
    have a Brother MFC 7220 that is leaving ghost images of whats being copied or from fax's being received. The hot roller and press roller don't have any toner residue on them so don't believe coming from them. Also cleaned mirrors and glass available to clean. The drum does seem to have some toner residue left on it. The account has to get refurbished drums, not allowed to order new, could this be the problem, or is there something else i could pursue as the problem.
    • 22930
    As likelyhoods go, it's either the fuser of drum cleaning. What intervals does the image repeat at? =^..^=
    • mattchall
      • 24
      I would bet on the drum especially if they are generic/refurbs.
      • austonrush
        Sharp & HP Tech
        • 234
        This is likely going to be a drum or toner issue.
        • E Winter
          Probably - just check the space between the ghostings and take a look at the service manual where you can find the diameters of the fuser/toner/drum - if you don't have the manual you can ask in this topic, I can take a look then..
