Hp designjet 4520 86-01 code
  • 1stcavvet
    • Apr 2015
    • 231
    [Error Code] Hp designjet 4520 86-01 code
    Customer said it would do this every once and awhile----Of course ----Called me to replace the shredded carriage belt, Put the belt on start it up goes thru initialization and comes back to the right and stops dead about a foot from the service station 86-01 possible paper jam. tried it a couple more times after checking that the tubes weren't catching cleaned the encoder and still comes to a halt about a foot from the service station I see it move to the right while initializing then to the left and cleaners move and as the carriage come from the left back to the service station it stop a foot from the the station. I was thinking encoder but the the customer tells me it happens a lot I think it might be the motor to much resistance?? anyone have any ideas lack of lubrication maybe???
  • Kiran Otter
    • Dec 2013
    • 1092
    Re: Hp designjet 4520 86-01 code
    Encoder strip would be my guess. The motors rarely ever fail. See my other post: What a damaged encoder strip looks like from a Designjet
    It's very easy to miss the damage to the encoder strip.
    Kiran
    • theengel
      • Nov 2011
      • 1784
      If the carriage has a lot of resistance, maybe. Usually, if you're replacing the belt, then you clean and lube the rail while you have it off. But it's probably the encoder strip.
      • Massimo Italy
        • Feb 2021
        • 45
        hello everybody,
        i'm going crazy about this problem ..
        I state that the plotter worked but had the belt at the end of its life, I advised the customer to wait for the replacement and not to use the plotter but he continued and the belt frayed and wrapped in the tensioner ..
        Then when the new belt arrived I went to replace it and from that moment the problem of the first post occurs continuously.
        I cleaned the motor pulley and oiled the guides.
        The carriage moves freely with the hands but stops following a slight vibration when it is pulled by the motor.
        I replaced the encoder strip and sensor with no improvement.
        If I loosen the tension of the belt the carriage reaches the right but when it restarts quickly to the left it re-locks.
        The bushings remain to be replaced, but I have never had to do it, not even on the most worn out machines, moreover it worked perfectly before...
        Any suggestion?
        Thanks in advance, Massimo
        ps. the other plotter of my first post has been collected and replaced at the customer and is in stock awaiting treatment, I must follow the advice received.
        • Kiran Otter
          • Dec 2013
          • 1092
          There is a 2nd rail up in back of the carriage that it slides along. Make sure this is clean. I've run into a similar issue and found this rail was caked with ink.
          If it's not that, I'm not sure what to suggest. Make sure the tube assembly is installed correctly and not broken, it can cause interference at the carriage where it mounts to it.
          At any time did you remove or attempt to remove the bushings in the carriage? If they're not installed correctly that could have an effect on how the carriage rides (namely the height of it.) I don't recall if they can be removed like on the 500.
          Does it have the same problem with the printheads removed?
          Kiran
          • Massimo Italy
            • Feb 2021
            • 45
            hi Kiran,
            i also cleaned the guide you are talking about, the plastic bushing works perfectly.
            Even the tubes are well positioned and do not interfere with the movement of the carriage.
            Yes the bushings can be removed, I have cleaned and reassembled them several times, even reversing them, but the defect remains the same ..
            The main bushings have a slight movement, they do not adhere perfectly to the axis.
            But, if I remember correctly, this is also the case on the 500/800 ..
            I haven't tried without heads, but they don't touch bottom.
            Massimo
            EDIT
            I forgot to mention that I have run the axis test and passed the encoder check phase when the carriage moves to the right slowly to restart quickly to the left, immediately it stops with code 86:01.
              • 22695
              When the belt degrades, quite often some of that rubber dust packs into the timing pulley on carriage motor. I've had to scrape out the teeth of the timing pulley of the motor with dental tools. Also make sure that the belt is tensioned correctly. =^..^=
              • Kiran Otter
                • Dec 2013
                • 1092
                I always have to do this! I carry a couple picks and a brass-wire brush for just this purpose.
                Kiran
                • Massimo Italy
                  • Feb 2021
                  • 45
                  I certainly cleaned the motor pulley and removed any remnants of the old belt, but the tensioner has a fixed position and is not adjustable.
                  As I said before if I loosen it the defect remains but the block area moves.
                  I ordered the bushings, we'll see when they arrive.
                  have a good weekend.
                  • Massimo Italy
                    • Feb 2021
                    • 45
                    Finally the bushing arrived, I mounted them and the problem is exactly the same!
                    The engine remains to be replaced, but is it possible that it has no problems at low speed and when it turns faster it brakes or slows down?
                    The plotter worked before the belt broke.
                    Anyone have suggestions?
                    Thanks, Massimo
                    • D Hook
                      • Mar 2018
                      • 205
                      It IS possible to put the belt/tensioner on backwards, pulling the belt off to one side instead of running straight. I've had that experience on a 4500 once. Assuming you have the covers off yet, you can watch the trajectory of the belt as it moves across the printer. When it gets near the tensioner it may show some deflection instead of running in a straight line, throwing off the counts of the encoder strip or causing extra resistance in the carriage movement.
                      When the power is off and you move the carriage by hand, does it exhibit any resistance in the same place where it's stopping when powered up?
                      Following this thread because it's an interesting problem and anxious to see the solution.
                      • Massimo Italy
                        • Feb 2021
                        • 45
                        Hi Hook,
                        I'm happy to have fans, I just hope this story is successful, and doesn't end with the plotter's defeat or mine.
                        Seriously, you have made a pertinent observation, I do not observe any friction in the sliding of the carriage without power.
                        But a vibration is triggered right in the center just before it stops, I am convinced that some effect is caused by the tension of the belt but I don't know how to fix it.
                        • Kiran Otter
                          • Dec 2013
                          • 1092
                          I wish I knew what to add. Dumb question but have you lubricated the carriage rails? And with what?
                          Kiran
                          • Massimo Italy
                            • Feb 2021
                            • 45
                            Hi Kiran,
                            I cleaned the axis and tried various lubricants, Teflon, for weapons, in short, nothing pasty, the carriage runs without problems or friction.
                            I am thinking of lowering the motor slightly, maybe using only one screw, jast for testing.
                            • D Hook
                              • Mar 2018
                              • 205
                              Originally posted by Massimo Italy
                              Hi Hook,
                              Have you checked the belt alignment as noted in other post? I'm with you, it sounds like a belt issue to me. Especially if you've replaced the encoder strip and sensor. With the covers off, I'd observe carefully what the belt it doing.
