Morning all! We have an HP T1600 plotter thats throwing a 85D0-9138-0000 error code when receiving print jobs from adobe reader running Win 10 64bit using the HPGL2 driver. The system prints using the PCL,PS,PDF drivers without a problem. Only issue with using these drivers is that they dont have some functionality which may be related to user rights, Colate, first page on top, are not executed when selected. These options worked before using the HPGL2 driver, but cannot currently be used as it is making the plotter code out. I have updated the plotter to the latest firmware version available (CYCLOPSNEPTUNE_07_21_20.1.fmw) and have removed and reinstalled the HPGL2 driver to no change. Any direction or insight on this problem would be greatly appreciated.
Thank you!
JC
Thank you!
JC
