HP DesignJet T790 stuck at 33 or 34%. (sometimes it show 08:04 error)
  • Keeper
    • Apr 2022
    • 2
    Hi there!
    I need help with HP DesignJet T790. It stuck during initialization. Usually at 33 or 34%. Sometimes it show 08:04 error during initialization. Sometimes initialization process finishes completely, but in couple of minutes it show 08:04 error.
    What is that? Formatter board? HDD?
    Thank you in advance.
  • Lance15
    • Jun 2015
    • 1088
    Re: HP DesignJet T790 stuck at 33 or 34%. (sometimes it show 08:04 error)
    See if this PDF helps.
    T770, T790, T1300 and T2300 - Front Panel Hangs at 1% and After a Few Minutes Displays Error 08_.pdf
    • Kiran Otter
      • Dec 2013
      • 1115
      My money would be on the hard drive failing. CR650-67001 Designjet T790, T1300 SATA Hard Disk Drive with FIRMWARE (
      You can try removing the printheads and ink cartridges, just to rule out a consumable.
      Kiran
