Design Jet T120 Ink/print head error
  • digicor
    • Jul 2008
    • 1153
    Client changed inks, now they have this message, i tried resetting the print head and put the empty inks back in to see if its a ink problem, same message occurred, how do we get around this? the print heads are expensive to only find out its not the print head, I dont know how old the print head is, so any suggestions are welcome, Thank you
  • Lance15
    • Jun 2015
    • 1086
    Re: Design Jet T120 Ink/print head error
    These printheads are notorious for failing. I've replaced several over the years.
    • digicor
      • Jul 2008
      • 1153
      if we replace the print head, what is the replacement procedure? will the machine recognize the new print head and give me promts? or is there a back door service entrance? thank you for your input
      • Kiran Otter
        • Dec 2013
        • 1106
        You tell the printer you want to replace the printhead. You remove the old one, insert the new one, put the ink cartridges the printhead comes with in, and close the cover.
        Kiran
        • digicor
          • Jul 2008
          • 1153
          okay just asking because the printer is in a state of error and wont do anything , so ill open the ink door, ? take out the inks..and the print head.. then re boot it? and re install? correct?
          • Kiran Otter
            • Dec 2013
            • 1106
            I don't remember the exact order of things but as long as you have the inks that came with the printhead inserted, then replace the printhead, you should be good.
            The point of the included inks is so you don't run out of ink while priming the new printhead.
            Kiran
            • Lance15
              • Jun 2015
              • 1086
              There have been some instances this happened to me and I had to power cycle the plotter. When the carriage is in the middle of the carriage path, I pull the power plug so I can remove the inks and printhead. Plug the power back in and it will ask for supplies. Install the new printhead and the supplied inks.
              This procedure is invoked using the control panel. If the plotter is errored, you can't start the printhead replacement procedure.
                • 22997
                Kiran
                On the machines I worked on the plotter would not proceed with the printhead installation wizard unless you installed the four new cartridges included. You can re-install the partial cartridges later after you've used up the setup cartridges. =^..^=
